- Joined
- Mar 3, 2005
- Messages
- 3,599
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBD
- Vessel Name
- journey on
OK, I just went down to check the battery water in Journey On. We don't remove the batteries for the winter in SoCal. and I found the last remnant of the summer cruise. The cardboard from a 6 pack of "Pacific Pilsner Beer, the Coast Champ." Judy spent her hard earned money on that to keep me happy whilst we were in Refuge Cove. Pacific Beer in Canada, Pacifico Beer in Mexico. Both cheap.
OK, and what does this have to with widening a C-Dory bulkhead? Well, while I was in the boat, I looked at the bulkhead between the V-berth and the cabin. I'm going to offer a different view from what Bob gave as to the importance of that panel. Understand, I only speak for the 25; Bob has experience with the Tomcat, the 25 and the 22.
That bulkhead is fastened with 2 ea 1/4" bolts/lag screws on each side of the cabin, into the v-berth structure, which in itself is bonded to the inside of the hull. That's the only place in a C-Dory 25 those bolts are used. The hull and deck are held together by pop rivets (and adhesive,) not bolts. I don't know if they're bolts or lag screws, because I can't remove them, those suckers are in to stay. So the bottom is secure.
Now the top. The top of that bulkhead forms the shelf just below the forward windows. So that angle stiffens the bulkhead and allows higher loads to be transferred across the hull. There are 10 ea pop rivets holding that top shelf to the cabin molding, so it's there to stay also.
And the bulkhead's vertical section is plywood, covered with fiberglass. So that's not trivial. Bob's correct in saying there is no bonding at the sides.
My contention is that bulkhead, intended or not, adds a significant amount of stiffness to the structure, both in torsion and lateral movement. And I wouldn't want to do that. Removing it or cutting a significant amount from it has to reduce the boats structural stiffness. The original cutout is bridged by the top shelf, allowing loads to be carried across.
Of course, the flip side is that access to the v-berth sucks. I finally surrendered and cut out about 6" horizontally. That's about 25% of the original opening and was well worth it.
