Even if you can't tell exactly what type of paint you have, you may be able to determine type - or at least have a good chance of it.
Can you post a photo and/or describe the texture?
--If the boat is from fresh water and the paint is really smooth/hard/"thin" seeming, and does not rub off on your hand, then it could be vinyl paint.
--If the boat comes from a salt water area, and the paint has that velvety texture characteristic of bottom paint, but does not easily rub of on your hand, it may be a "hard" bottom paint.
--If the boat comes from a salt water area and the paint is velvety looking and a bit "soft" and does come off on your hand, clothes, etc. then it may be an ablative paint.
As a general rule, softer paints can be painted over harder ones, but not vice-versa. Vinyl can only be painted over with vinyl (VC-17 being an example of a vinyl paint - meant for freshwater use).
We may be able to help you by looking at photos and or you could describe how it seems in comparison to what I wrote above. Another possibility is that if a yard painted it you might be able to check with them.
Here is a compatibility chart from West Marine that gives more information:
http://content.westmarine.com/docum...Bottom_Paint_Compatibility_Chart_2012.xls.pdf
