I've noticed a slight list on my mooring on the port side. I know there is more weight due to the water tank and gear I have stored under my dinette but my real concern is water under the cock pit decking. Last season when I was drilling a hole for a new bilge point I had water start to spurt out of the hole when the drill broke through the liner. I contacted my dealer Y-marine and they said there should be a drain hole in the bilge for water to get out from under the decking. The only way I could drill the hole was to go through the drain plug when the boat was on the trailer. I did this and a lot of water drained out. However maybe stupidly I never plugged that hole. In July I had a battery problem and the boat cockpit filled a little with water. What I'm wondering is can water be entraped under the liner and water log structural members or is the hole to small that I put in to completely drain the area under the liner? I'm thinking of installing a inspection hatch. How much water can get in the void and is it possible that it's causing the list? Thanks for any input.
