moonular
- Joined
- Jun 6, 2011
- Messages
- 12
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 19 Angler
I have a 2004 Angler 19 and want to upgrade the bilge pump system. The factory installed "on-demand" pump back between the fuel tanks will do nothing but drain my battery (periodically turns on by itself to "check" for water).
Two problems; 1. There is no recess in the deck to set a bilge pump/float switch into even if I wanted to install a better one. 2. I have read in this excellent forum that water may not even drain back to the fuel tank area even if there was a way to "recess" a float switch back there (unless maybe if the fuel tanks are kept topped off). Thus many 22's have it up forward by the cabin blkhd.
I will be keeping the boat in the water all year long in the PNW and bvelieve it or not, the old funky marina it will stay in does not really have reliable shore power so installing a small batterycharger won't help either. It looks like the best choice is to have a cockpit canvas made to keep out rain & snow but I will want the pump to work while at anchor as well.
So I am wondering what my choices might be. I have a small solar panel (5W) but I know that won't do much. Should I just leave the existing bilge pump installed and install larger solar panels?
Should I get a full boat cover made instead of just a cockpit cover?
Is there any areas in the deck that even have enough depth to fab & install a recessed area for a small bilge pump & float switch?
Any and all suggestions would be great!
BC
BC
