Best propeller
oldsen
Hi folks
I have a 25 cruiser with twin 90 Honda engines.
Anyone have advise as to the best prop size and make? I am looking for higher top speed than my current 13 inch 3 blades
I have done a load of research but keep getting conflicting advice
Appreciate any and all assistance
higher top speed than?
what pitch are your props?
what is the current rpm at WOT?
As A Fishing C says,
We need WOT RPM, and speed by GPS.
We need to know more about current props: Pitch, diameter, material (SS, Aluminum or composite?)
Are these stock props, or have extra cup, and rake etc?
What is cruising speed by GPS and RPM
How is your motor mounted? (height)
How do you trim your boat?
What altitude is your boating?
There are also prop specialists, such as Pro Gods (propgods.com) They will answer specific questions especially if you have some unusual issues. Start with the basics here, and if you are not satisfied then go there.
