Best C Dory 22 Cruiser Toilet/Privacy solution (besides the berth)
Ripdotcom
Jun 22, 2026
6
3
Location
Tallahassee
2004
I will keep the porta-potty between the fuel tanks if necessary. I thought of doing a "hide-a-potty" solution on the starboard just behind the galley window. Perhaps a cooler style with a potty and mini tent in it, and a cushion on top that doubles as a proper seat. My most outlandish idea is to fabricate a vinyl 28"x28"x72"vinyl privacy tent that is semi-permanent in the same area. What is everyone using for multi-day trips? thanks.
Too be honest.. what we use is a rectangular shaped plastic bucket with a tight fitting lid. We keep a 1.75L yogurt container in there for #1. (Peeing over the side ruins the wax job.) For #2 we use the bucket 1/2 full with seawater and snap the lid on tight. We can leave it there for a little while then we run out to sea a couple of miles to let it self macerate and then we discharge it into the sea. Rinsing the containers in the salt water keeps them fresh and it seems to work. Of course if there is an outhouse or toilet on land we will run over in the dinghy and use that. I like the rectangular bucket be cause it is more the shape of a toilet if you sit on it with the corner between your legs.
Funny thing to post but it is a legit question.
I should add for privacy I find if I sit behind the bulk head on the port side, I can open the cabin door and I can do my business shielded to the port by the gunnel and to starboard by the door. The low deck on the Dory is such a wonderful feature.
For #1 we use pee-bottles and for#2 we use a "potty" seat with compostable plastic bags (doubled) that are sealed and discarded after one use. Many such potty seats are foldable when not in use and can be stored out of the way.
My father's boat had only thru hull cockit scuppers, and no thru hull for drains or heads. The "head" was a galvanized bucket under a wooden round seat (not the most comfortable) in a wooden box which also served as a seat for dinner in the cabin on my father's 26' sailboat. The bucket was emptied at sea on the way home, or if staying for some time, then the dinghy rowed to 3 miles off Catalina, was used to dump the bucket.
The only head in the C Dorys I have owned which I did not like was the 2003 C Dory 25, which had a Jabsco manual marine head in the bathroom, but the 20 gallon holding tank was way back under the splashwell, with a macorator pump overboard or a suction tube for a land based pump out. It was a real problem if the electric macerator pump went out--as it did in AK, where finding another macerator pump or a rebuild kit was not readily available. We had to have a guest bring a new pump from West Marine in USA mainland.
In the second, 2007 C Dory 25 the boat had an airhead, which I felt was the best solution--problem is difficult to use an AirHead in a C Dory 22. Our 22's both had portipotties. I have a 3" direct sewer connection for my RV Pad at home, as well as a bathroom which directly enters from the outside of the house as well as inside (for swimming pool use), so pouring the content of the portipotty was not a problem. Lake powell has SS sinks for pouring out the content of the Portipotty at Lake Powell, and other places such as Catalina, offshore in both East and West Coast was go 3 miles to sea and pour overboard. The C Dory 255 Tom Cat had the self contained Sea Land Commode with 9 gallon holding tank in the base, with "Y" valve to pump out or Macerator overboard discharge. In some no discharge zones, the thru hull manual overboard discharge had to be disconnected--not even a locking "Y" valve does not fulfill the regulatons in those No Discharge zones.
After the experience with the bad macerator pump, I carried a rebuild kit and another new/rebuilt Macerator in my "spares". Same for pressure water system, as well as keeping the foot pump, "just in case". I learned very quickly that the water pump was most likely to fail when Marie was in the shower! With quick disconnect on the water and powere, I could get a second pump working in a couple of minutes...Happy wife!
I use the swim ladder platform. Yoghurt container for #1
fantastic! So after further reading on all the replies, I have realized that I am now on track with my original idea. I will get a small 12v compost toilet
And a 5-6’ tall cloth portable armoire. Then we can just store everything between the fuel tanks and pop up when it’s time. Or just a shower tent and toilet. Thanks
You might look at Trelino toilets.
I have a manual compost toilet and it works very good, with very few things that can go wrong and no need to do or rely on any electrical work.
sounds like a great idea.. I was looking into that originally but all the ones I looked at were to big to fit in the Cuddy Cabin.. Maybe it could go on the deck if it was small enough.. Hmmm you got me thinking!
I should have mentioned this idea was specifically for the deck. Everything should easily set up directly behind the galley on the deck. Or I could incorporate a pop-up two wall divider and simply open the door on the starboard side and already have two walls.
Some of the 22's have an all glass door, so that :side is gone for this purpose. One of the 22 owners took out the dinette and put an enclosed head on the port side aft. I believe he left the "navigator/admiral" seat on the port side. There are specific shower enclosures--we have owned a vinly on with an inflatable top and water or sand in the bottom bags, which is the same as a built in, use as necessary, enclosure in the cockpit. We have never used it on a C Dory, in that we pulled the portipotty out from under the seat at night to use, or took the filler cushing of the V berth out during the day, and used the cloth or vinly piece which can give "privacy" and close off the V berth area.
It depended on where we were, but often the port potti was put in the cockpit. The high gunwales and low floor made this resonably private from off board viewing. People in the cabin were eyes front while the toilet was being used.
