Hello fellow Cbrats,
I was able to fit three group 24 batteries, battery charger, switch, Victron BMV post and three breakers in the starboard lazarette. I just uploaded a picture of the setup to my album. I was very happy with this setup as it made the best use of a small space and everything fit......then I launched the boat.
When I launched the boat on Lake Tahoe I immediately noticed the boat listing hard to the starboard side. It didn't dawn on me right away and after a night on the water, I woke up the following morning and thought.....duh. It was so obvious. Too much weight in the starboard lazarette was causing the boat to list hard.
So now my question is obvious - Where do I move my "house" batteries - which consist of two group 24s? It seems like my best two options are between the fuel tanks in a sealed battery box or to the port lazarette. Ryan at Sportcraft Marina suggested they be moved to the port lazarette to achieve good weight balance. I was planning on using the port lazarette as a place to put rockfish, etc because it drains and I can fill it with water and I don't really want give up this space. He said it would need to be property vented (i need to drill a lot of holes in the base of the lazarette). Once I do this, there is no turning back.
Suggestions? Thoughts?
:thup
:thup
