Marco Flamingo
Active member
- Joined
- Jul 9, 2015
- Messages
- 1,179
- Reaction score
- 8
- C Dory Year
- 2004
- C Dory Model
- 16 Cruiser
- Vessel Name
- Limpet
Sunbeam":28ehyf59 said:Maybe I'm not quite getting what you mean.
I wasn't clear. I was referring to the screws holding the wires that go to the nav light that are screwed up into the deck in the V berth. Every 8 inches there is a screw holding a zip tie. I suspect that those screws are through the fiberglass and into the core. Even though it's on the inside and protected from the weather, I still don't like the idea.
Much as I like the weld mount fittings, I was standing in the checkout line at Fred Meyers this afternoon and saw some of the first Christmas stuff on display. It was clear plastic stick-on hook gizmos for holding a string of Christmas lights. 10 for $3.99. Might have to spring for a pack and try them out for holding the tiny wire loom to the nav light.
Now I'm not sure if my hull was vacuum bagged. I finished cutting out the bad balsa and found that I had to chase down black stained kerf lines that lead off in various directions (though generally in the shape of the pop rivets holding the seat box). The area where the resin had wicked up into the balsa may have been a fluke. I'm still amazed at how firmly the polyester resin hold the balsa.
Mark
