Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,946
- Reaction score
- 291
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
The Honda 130 on the C D 25 runs like a little jewel (fired it up after polishing the fuel, putting in a coarse fuel filter before the flow tranducer, and new Racor). The "pee" is a little "Weak"--not sure what the Honda should be like on muffs--but since I suspect that this is the orgional impeller (2003 engine), I will change out the impeller tomarrow.
Are there any special tricks which are unique to the Honda 130? I have changed a number of inboard and outboard impellers in the past, and some times there are little hints or lining up the shift shaft, or the pump gromet etc. Also any preference on servcie manual: Clymer vs Seloc?
