Angler anchor? & best gelcoat cleaner?
East Coast Brat
Jan 12, 2010
11
2006
19 Angler
Hull Identification Number
cdo19081g506
I need to know the stock anchor for my 2006 19' Angler. I got it stuck on Moosehead lake last week and had to cut it. I need the make and size in lbs. I think it's " something claw anchor" Also what is a good gelcoat cleaner. Thank you for all your help.
If you choose a claw, I would recommend a Rocna. Pricey but will set much better in varied bottoms than a standard Bruce or similar claw. Might check out the fisherman model which will let you retrieve it easier.
A lot depends on what you want to clean off the gel coat. Generally there are a number of products with a mild to moderate acid--such as oxalic acid which will remove the "Waterway smile"--tannins which stain the gel coat. Oxalic acid crystals to a saturated solution can be obtained at a big box hardware store or paint store. Starbrite, Davis, Mary Kate (on/off) all make similar cleaners at a greater price. More toxic are items such as snow bol toilet cleaner, which contains hydrochloric acid, or more concentrated Muiratic acid. My personal feeling is that these are harsh on the gel coat, but many professionals use them.
For buffing out the hull, and removing oxidation it depends on how bad it is. There are heavy duty rubbing compounds (abrasive) to Finessett it II from 3M, and I would also include the Colinite 920 cleaner in that category as an excellent product (followed by their fleet wax).
Then there are the combination products which have cleaner wax--and of those I like Meguiars Flagship cleaner wax. However there are a number of cheaper products which will also do the job.
What kinds of anchors do the locals with good boats (as opposed to bargain junkers) use? They'll know what works in your local conditions.
