So I found sea water under v berth. I put red coloring in water and poured it into locker then then vacuumed it out through plug used to put foam in .It was red
My boat is a 2007 25 ft cruiser
So I cut a hole in v berth and removed massive amounts of water logged foam. I could feel where the drain hole had nicked the void into the v birth
Any suggestions as to how to repair this drain?
