williamsburg
Much of our boating on the CD-22 consists of staying overnight in marinas, gernerally traveling with 3 or 4 other boats. Here in Tidewater Virginia the heat and humidity combined with our age and infirmity makes air conditioning a necessity in July, August, and September. We finally took the step but I am not completely satisfied with our decision. The choices we knew of were:
Marine Air Condit - These are efficient units and are out of sight. They are expensive ($1500 for 6500 BTU), require two thru-hulls and you loose a cabinet. Since the hull shape requires that the intake thru-hull is just below the water line it attracts junk - especially jelly fish in our area. The water intake is often clogged - at least for my fellow C-Dory owners.
Camper Top Air Condit - They are efficient, relatively inexpensive, and do the job. But the lines of the CD-22 are so pretty and this really changes the looks. Also there is the problem of the condensate dripping off the top and the units are not made to withstand the rigors of salt air.
Hatch Insert (Cruisair Carry-On) - These seem to work well in cooling the cabin. They are expensive ($700+). They are a storage problem, 30+ inches in greatest dimension. The difficulty of handling the 60 lb. unit on the foredeck caused us to rule out this unit.
Stand Alone Portable Air Conditioner - This is what I finally choose (Soleus 8000 BTU) about $400 from Staples including shipping. This unit measures 12.75"wide, 16" deep, and 31.5 high. If you remove the casters and use 3/4" feet it will fit under the table top. I removed the table leg and use the unit as the support. It is easily vented using the supplied kit through the port sliding window. The table and seats are still usable. Now the problems - By nature the portable air conditioners are very inefficient. First they themselves are heat generators, especially the vent tubing. Since they use the inside air to cool the compressor, cold air is removed and sent out thru the vent tubing. This creates a vacuum in the cabin sucking hot outside air in. During the heat of a sunny day cooling is minimal (3 or 4 degrees) but the humidity is decreased. At night it cools the boat nicely. There is no thermostat so you can get too cold and have to turn it to fan manually. Finally we have had problems getting rid of the condensate - severaly gallons a day. There is a drain to which you connect 1/2" tubing and can drain into the bildge pump area. But the unit is very sensitive to leveling and can pour alot of water into the cabin. We have made a drain pan from a plastic basket and this works fine.
Will take some photos next time I'm at the boat if anyone is interested.
Drink Heavily - May be the best device to get to sleep in the heat and humidity
