When changing out the wiper motor on our 25 a few years ago, I had to cut the shaft to remove the blade (the motor was shot, so I wasn't worried about the shaft). I tried penetrating oil, some "guaranteed to cut through corrosion" stuff, heat, swearing, all the muscle I could muster, and more swearing to remove the wiper blade from the shaft. Swearing gave the best results until I decided two days of messing with it was enough and just cut through that SOB.
I think the 22 and the 25 use different wiper blades (the 25 is a pantographic fixture); you can open the motor and set the arc. IIRC, the motor came in with the smaller arc and that is the way ours was set up from the factory. The 110 degree arc worked better for the bigger window on the 25. Unless you hear from someone with experience with the 22, I think I'd be inclined to try it with the 80 degree setting. Also, put some marine grease on the shaft and the fitting for the wiper before mounting it all up.
I seem to recall that there were about 50 set screws holding the blade to the shaft... that may be horrific flashbacks, and it may only be 2 or 3, each located in a place best suited for those who are triple jointed.
The port wiper on our boat is getting slow, so I'm probably due to practice up on my swearing again. Or dynamite. Or sell the boat "as is, with one really great wiper".
Kidding aside, it would probably be a much easier job if you weren't trying to do it in blazing sun and 400% humidity.
Other than that, it's a snap. :wink:
