I mounted an auxiliary outboard bracket to the stern of my 25. It is a Panther 55-0022 adjustable mount.
Here is what the bracket looks like in the fully up position.
Here is the fully down position.
Both positions clear the trim tab by a wide margin.
I added a cleat as a security tie-back and it also helps with the wobbly mount when underway.
Now, before anyone lashes out and tells me how stupid it is to have a tiny outboard as a backup motor, this mount is PRIMARILY for stowage of the dinghy motor. It just HAPPENS to be that the lowering bracket will allow a short-shaft to operate in calm conditions.
I had the opportunity over the past couple of weeks to mount a Mercury 3.5hp four stroke (the photos above) and a Honda 2hp four stroke on the mount. I ran each of them just to see. In perfectly calm conditions, with no wind or current, and a moderately-loaded boat, I found the following:
Merc 3.5 - 1/2throttle - boat speed 2.9mph
Merc 3.5 - WOT - boat speed 3.4mph
Honda 2 - 1/2 throttle - boat speed 1.7mph
Honda 2 - WOT - boat speed 2.1mph
In all cases, the main motor Honda 150 was able to steer the boat very well (considering) with the tiny outboards locked dead-ahead.
In each case, the motor is mounted right next to my aux fuel port http://www.c-brats.com/viewtopic.php?t=20814 so that it's tank can easily be topped off from the main fuel tank on the 25.
Just a couple of data points for those interested.
Ray
Ray
