Coastie Dory
- Joined
- Nov 2, 2003
- Messages
- 71
- Reaction score
- 0
Hi Marc, Dusty
I agree with you on the fuel issues. If one does not use stabilizer and use the engine frequently or drain the bowls, carburetors have been a nightmare. Fuel injection has gone a long way to eliminate the problem, but if the owner puts the boat away for a year or more without proper storage then the fuel pumps don't want to run. I have only seen injector issues on one of the Coast Guard SAFE boats that run the 225 Mercury (Yamaha) 4 strokes. Admittedly, the problem is directly related to fuel quality and not varnish or engine builder.
All of our fuel is at least 10% ethanol/chemical cocktail and the stuff barely lasts 3-4 weeks without stabilizer. The smaller the engine, the greater the issues. Idle circuits go first, then the larger circuits follow suit.
When the carbureted Hondas are running right you would never know they were not injected-same with the Mercurys. I think there is no bad choice as long as you accept the limitations and proper maintenance of the respective engine you buy.
Randy.
Randy.
