C-Nile
- Joined
- May 9, 2008
- Messages
- 638
- Reaction score
- 0
- C Dory Year
- 2012
- Vessel Name
- Betty Ann
For those of you who are interested -- I removed my Yamaha 4 Stroke 4 HP kicker from the stern of my C-Dory 16 Cruiser. The reasons for this were two-fold: 1) it threw the boat out of trim with two people in the boat, 2) my fuel economy had dropped off with 4.5 to 5 MPG experienced during normal conditions (with my Suzuki DF40 Outboard.) Since removing the kicker, my initial mileage results under less than optimum conditions revealed an increase to 5.9 MPG!
I believe strongly in the need for a kicker motor, nevertheless. In my area, SeaTow covers my entire cruising area, so I needed a kicker powerful enough to allow me to get out of a gunkhole, maintain steerage or get me into my slip (which is tight) after being towed by SeaTow.
I decided on a Motorguide* marine 55 pound thrust motor. It weighs only 20 pounds, and in testing performed over the weekend, it was powerful enough to make 1 mph headway against a 1.8 mph current at full power. At approx. 2.8 mph, this is approximately 63% of the hull speed for the CD 16. It was also adequate to maneuver into the wake of oncoming boats. Obviously, if I use it against a current greater than 2.8 mph, I'm not going anywhere, but for me I can live with that fact. Also, it may not be getting the maximum thrust capable with the standard, supplied 3-blade prop -- some say that 2 bladed power props are better served for that purpose, but I like the idea of a more weed-free prop configuration.
*Note: The MotorGuide VariMAX V55SW HT 36" 12V TLXMT Trolling Motor designed for salt water, was purchased at Walmart for $399.
