wapiti
- Joined
- Sep 11, 2007
- Messages
- 133
- Reaction score
- 0
- C Dory Year
- 1996
- C Dory Model
- 22 Angler
- Hull Identification Number
- DOR22719C595
- Vessel Name
- C-Breeze
Just wanted to share my recent experience with removing a rod holder from the outside cabin wall of my 22 angler. I mounted the aluminum rodholder with two screws and a liberal amount of 5200, Big Mistake. To start the removal process I first reviewed the posts you all provided on the topic. Armed with this information, made a flex cutter from some 50 lb test braided line tied to some oak handles. After about 15 strokes between the cabin wall and the rod holder frame the line broke. Tried cutting with braided line about 3 or 4 times with the same result. Moved up to steel down rigger cable and actually made a little progress cutting the 5200 adhesive, all of 1/2 a inch after 10 minutes. Decided I needed to go to plan B - a sharpened scrapper and a heat gun. With some careful heating of the aluminum frame and wedging the scrapper, the frame slowly popped away from the wall. The paint on the rod holder acted as the separating agent once it was heated. I am sure that if I had bonded bare unpainted aluminum I would not have had a much tougher time removing the rod holder. After a couple of hours of elbow grease as outline in previous posts I removed most of the 5200 from the cabin wall. In summary as mentioned before give some thought to what and where you are mounting items using the 5200 adhesive as it is no easy job removing it after the adhesive has cured.
Happy boating
Wapiti
Happy boating
Wapiti
