When that boat sells and the ad is pulled, there won't be any record of it here for reference, so I'm going to copy it here for permanent keeping:
2008 C-Dory 29' Venture - $145000 (Portland OR)
Date: 2009-12-09, 8:02AM PST
Reply to: see below
Brand new! Never been titled!!
Still on MSO!!! Includes full warranty!!!!
Yanmar 6BY260 6 cylinder 260 hp engine with electronically controlled fuel injection
Complies with tier 2 emission standards
150A 12 VDC alternator
5 kw Onan MDKBH generator
120 VAC 30 amp electrical system
50 amp 12 VDC battery charger
Galvanic isolator
12 VDC system
3 battery bank
AGM ‘no maintenance’ batteries
Marine air conditioning with reverse cycle for heat 18,000 BTU
Electric head with 28 gallon holding tank
Tank monitor system
Vacu-flush head system with features described above – 1 quart flush
Bow thruster with 88 lbs thrust
Hull – Diab balsa core
Deck – PVC core
Stringers and bulkheads – urethane core
No plywood used in construction
28' 8" length overall
9' 7" beam
2' 8" draft
26 knot top speed
18 knot cruise
150 gallon fuel tank with fuel manifold accessible from cockpit
44 gallon fresh water tank with dockside regulator
Aquamet propeller shaft
Nibral 4 blade propeller
Magnesium bronze blade rudder with hydraulic steering
Galley with water heater, refrigerator, stainless steel sink, electric range or Wallas stove
Sleeps 6 - Queen forward berth, double mid berth, and convertible dinette
Full head with stand-up shower
Large cockpit with aft seating and wet storage compartments
Large deck hatches for ventilation
2 opening port lights
Transom door
2008 Galvanized triple axle EZ-Loader bunk trailer 15,5000 lb w/disc
Brakes on all axles and side load guides
Will consider part trade for motor home, RV, or boat
$145,000
Call Jim, 503-708-3843
Joe. :teeth :thup
