Jack,
I rather doubt that a permatrim will improve your fuel economy on average and will likely slightly decrease it overall. The primary advantage of permatrims is that you will get up on plane at a slightly lower speed and you have a way of adjusting "pitch" that is independent of (and probably more fuel efficient) than trim tabs (which can then be reserved for adjusting "roll"). Hence, the speeds at where you might gain fuel economy with the permatrim are the speeds between where you get on plane now and where you will get on plane with the permatrims (probably a 3kt range around 12-15kts).
At higher speeds the permatrim will add a little drag and likely will decrease fuel mileage (albeit slightly). You'll also probably lose a kt or two on top end speed (at least that's my experience on my previous 22). What I gained from the permatrims was an ability to push the bow down in chop and improve the ride at higher speeds. To me this was a good trade off especially on a boat with twin engines and no trim tabs.
