22 hull specs?
Doryman
Oct 3, 2006
3,807
2006
255 Tomcat
Lori Ann
I'm trying to compare another boat's hull to the C-Dory 22 (not classic) but am stymied when I search online for some of the specs.
I have found
Length 22'0"
Beam 7'8"
Transom height 20" (not an official spec; is this correct?)
I am unable to find
Inside depth
Deadrise forward, amidships & aft (in inches)
Side height
Can you help? Thanks!
Hi Warren:
My transom measures 20" (close enough)
Depth of cockpit to the floor (removable) is 32 " aft Chine to Gunnel is 38" Forward the freeboard will be more.
I am not sure what you mean by inside depth?
The dead rise is 2 to 3 degrees aft. There is some moderate increase, but not much until you get close to the windshield--where I would say it is 20 degrees, all of the way forward, it is a little more than 45 degrees--theses are eye ball estimates. If you want specific stations measurements I do have an inclinometer, and can give you precise (actually the I phone will also work well this way, with an app). Give me inches from the stern, I will be glad to give you a dead rise measurement in degrees. (which is the usual way to measure).
Thanks, Bob.
I think inside depth is what you measured as depth of cockpit.
Like you, I am used to specifying deadrise in degrees but this particular hull is specified in inches.
I can eyeball it for the other dimensions.
Since Warren sent me the PDF link to the boat he is considering, I have to disagree about the deadrise in inches. It is always measured in degrees; It is in this boat also. By definition:
Deadrise: is the amount of V-shape on the bottom of a boat’s hull, measured in angles at the transom of planing powerboats from the horizontal plane.
Doryman":m116ds6d said:
Thanks, Bob.
Well, if you know your distances from the center to the chine, and the inches of deadrise, converting to degrees is a simple matter of trigonometry. If you aren't mathy, post your numbers and I (or I'm sure someone else who might beat me to it) can help calculate so you can make an apples to apples comparison.
My post may not have been clear--the PDF gave the deadrise properly in degrees. Now as to what "amidship;s" really means--and forward really means in that specific boat. That is why deadrise is typically given at the stern--Deadrise elsewhere in the boat will be variable--wth the exception of a cross planked Garvey or other flat bottom boat.
You are right -- the PDF is specified in degrees. Sorry, my bad.
Doryman..........
Have you ever found Dr. Bob to be wrong?????
Jack in Alaska (Az. today though).
