I have a 2004 Tomcat and I think my water holding tank or tubing is leaking. When I fill it up I am getting water in the starboard pontoon that my back starboard bilge pump is pumping out. My boat's design as the water intake on the port side then it runs under the galley and is pumped into the sink and (is supposed to) drain out the side. There is usually water in my tank during a trip, but it seems like a constant slow leak into the starboard pontoon.
My sink water pump was leaking this spring so I replaced that, but it seems like there is a leak in the tank or the tubing under the galley as well. Has anyone had to check the connections or replace the tubing? How do you access the tank?
Thanks for any help you can provide.
