2001 honda 40 hp
FIMAN1
Question to all you experienced boaters. Would you be afraid of a 18 year old outboard engine and how does the C dory handle with 2 40hp engines?
That is a lot of question.
The answer would depend on a lot of variables.
How many hours on the OB?
What kind of maintenance has been done?
How has it been kept up?
(The last 2 are the most important.)
What boat are you putting the OB on? (Twins?)
I run twin 40 Yamaha's. (1600 hours an 14 years, always maintained, always treated right.) The boat handles fine. And for slow speed maneuvering, like in and around the marina it handles easier and better than a single -- ahh I know that is going to get some flack, but it does.
If I could have the same weight with twin 50's I would go there. My preference is for Yamis because I boat extensively in Canada, and I could get service and parts there. (Honda not so much - and there is plenty info on that here on C-BRATS site.)
If you have (or are) a good mechanic, and the engine checks out OK, I would not be afraid of it unless the hours are over 3 grand. The water taxi guys I have talked with will run their taxi OB's out to 3 or even 4K hours, then take that engine and put it on their fishing boat and put a new one on the work boat. (Most of those are in Canada and are Yamaha).
I second what Harvey said. I wouldn't be afraid of 2001 bf40s at all, in fact that's a great setup. We ran that setup for years and was very satisfied. The only issues we ever had were from ethanol fuel plugging up the small carb jets. Also the water pumps would sometimes suck up a chunk of something in the water and block the 'pee" hole. We would bring a piece of string trimmer line with us to clear it out to prevent overheating and continue on our way. Put countess hours on those motors and they were great.
The only thing to consider is newer motors will have fuel injection, which is nice. A lot depends on how they were maintained and used, but this model was built pretty robust.
I can also comment about parts availability because I was a little shocked when we crossed over into Canada and needed a fuel line, it was very difficult to find. We carried spares with us after that for that reason.
Good info Harvey & Paul.
Fiman, I have twin Honda 1999 40’s on a CD22 with just under 2400 hours on them. They are well maintained with me having done most all the maintenance. This is my 17th boating season running them & they start & run just as strong now as ever. Most of the time their power output is more than adequate. I’m presently considering replacing them, but only because of my preference for boating in the more remote SE Alaska areas & even with good maintenance, more hours & years of use does increase the odds of having near future problems. If Most of my boating was done where the other motor could easily get me back to the launch, I would keep these motors until one had a major failure & that could be a long time in the future as the motors have been trouble free for the last several years performing flawlessly last year in SE Alaska, Yellowstone Lake & Lake Powell & so far this year. How much the increase in cost will be for higher hp twin motor replacement will determine whether I stick to the 80 hp Honda or Tohatsu or go higher with either Tohatsu, Suzuki, Yamaha or Honda or even just stay with older Honda’s awhile longer. The slightly more heavy alternatives are under consideration now too, but I will stick to twins. The new motors with much more hp for very little weight increase is making the higher cost a difficult decision.
The older honda motors were well built motors, so if they are well maintained & the price is right it wouldn’t have stopped me from purchase unless another boat in the same or better condition with newer motors was available at a price I could afford.
I'm with Harvey. I have a 2002 CD22 with twin Honda 40's, put about 80 hours/yr on the boat since new and have only had to do normal maintenance on the engines - oil and lube (annual), filters (every two years), and water pumps (only on 3rd or 4th pumps in 18 seasons) - never any issues except recently an overheat alarm sounds but there is definitely no overheating, must be a bad sensor. I'm very happy with my setup. I mostly cruise at 13-16 mph (2 engines) or fish at 2.5 mph (one engine).
WeekiTiki":vstmhbg0 said:
My question in regards to small twins
Is how do they track?
Seeing that they're both right hand screw
If you are asking about forward direction. they go where you point the boat.
If asking about reverse. No prop walk noted. With twins maneuverability is easy, forward or back.
SleepyC:moon
SleepyC:moon
Really, reversing I figured they'd pull you starboard, big time
Hi Martin,
Maybe it's a "Yami" thing.
Even if it wasn't, it would be easy to overcome with twins -- differential throttle.
WeekiTiki":2ws4zlxq said:
bridma":2ws4zlxq said:
Hi Harvey,
There are so many more positives with twins. The "single" guys don't know what they are missing.
Martin.
How about fuel economy?
...and do the twins have hydraulic steering?
I have 1600 hours on my Yami's, and they are only half used.
As to economy. I spent 14 hours, cruising back and forth infront of the Kingston ferry doing escort /safety for the SEVETY/48 race. Admittedly, slow cruise for most of the time, but 14 hours, and I used 7 gallons of fuel. I would say that is pretty economic. (Yes, much of that was on a single engine, but that is an advantage of having twins, I can do one or both.)
Hey, single guys, are we going to let all this twin talk go unchallenged? I think we should start a forum like Singles vs. Twins, or something. I don't think that's been done before.
In the history of the C-Brats forum, it is probably the most discussed subject. There are no winners. You will not get a "single" guy to admit, "I wish I had twins", or vice-versa.
I do love the subject though, and if you are going to get involved, put on some kevlar body armour and a hard hat.
Martin.
Hey Brock, How about a little Water Ballet duel. I saw that done with some huge Canadian Navy tugs in Victoria harbor one time. Really cool what they can do. They actually made them dance on the water.
