Les Lampman
I decided to post here so all y'all could relax a bit and not have to form a defensive line in front of me (as much as I appreciate it and the comments).
I do not believe that T-Dog is in any way calling into question my personal integrity or honesty about the 1981 C-Dory. I've pushed for a survey right from the start which I think is only prudent on a 1981 hull for the cost involved. Initially he wanted to conduct the survey himself and I lobbied hard to have a pro look at it and save T-Dog a long trip if the survey didn't come out well.
I totally agree on everything that's been said about surveys and almost always I go right along with all the normal procedures. Not this time and perhaps I'll pay for that in the end but my heart was in the right place.
On my side of the fence the biggest factor was the potential buyers timing. He had hoped to finish up the deal within a day or two. Rather than give him list of potential surveyors I told him I'd do my best to find one that could respond on very short notice. I had 3 to choose from and I picked the closest one because he is close and also because he's got years and years and years of experience and knows the C-Dory boats. He's a retired Navy officer and as honest a person as I've met. I set up the survey so that he was working directly for T-Dog and told him (T-Dog) that he'd pay around $200 for the survey. That's what I thought was going to happen.
What happened to that plan was basically me. I told the surveyor to really check the boat out well because if the survey showed a problem that would keep T-Dog from buying the boat that we wanted to know what needed to be done to make it right. To that end I had told T-Dog that if he did the survey and bought the boat that he'd pay for the survey but if he decided against the boat based on the survey that we'd pay for it. That's unusual but if T-Dog didn't or doesn't buy the boat I wanted the information anyway so that we could address it. That way T-Dog wouldn't be out any money for a boat he didn't buy and we'd know what issues to address.
As far as the surveyor goes we're not in a position to feed him a lot of surveys. Not only do we not do a lot of surveys but it's been pretty well split up over the years between 3 or 4 of them. Also, the surveyor had no motivation for not wanting to report everything he found since both T-Dog and EQ want all the details. T-Dog of course wants the survey for purchasing purposes but we wanted a well done survey for two reasons: I absolutely wanted to make sure the boat was in good shape if it was going to T-Dog (my insistence on a survey was as much for me as for him), and I wanted to know what to repair on the boat if it came to that (with no withheld information). I suppose I could have had T-Dog do the survey and then if he refused the boat offered to purchase the survey from him but I chose to make it an easier situation for him.
Yes, the surveyor is supposed to be working for the buyer and his/her interest and I too insist on that to avoid possible influence from the seller (and/or broker). In this case the seller and buyer are fully aligned and we both want nothing but a full disclosure, which is exactly what has happened and I was still able to insist that the surveyor work for the buyer.
I told T-Dog I didn't want to sell him the boat without a survey and I meant it. I don't want anyone to ever purchase anything from us that isn't what they thought it was. Having a boat is supposed to be a fun thing and buying it shouldn't give you (more) gray hairs and heartburn.
From what I can tell (and I haven't asked the surveyor directly) he didn't charge T-Dog for a couple of reasons: he feels he didn't do a full survey since he was able to call after using the moisture meter, and because he feels that it's likely to end up in our (EQ's) court and we'll have to work with him further to get more specific information.
What's specifically at issue is a matter of personal interpretation. If two folks went to look at a used car and the automatic transmission slipped slightly you could get two completely different reactions. One person might say "Oh, no big deal, this model of transmission does this and with a good service will probably work just fine." and another might walk away thinking "I'm not getting involved with a transmission problem."
What's been found so far is about an 8" in diameter area just starboard of the centerline just aft of rear cabin bulkhead that sounds duller when hammer tapped, shows a higher moisture reading, and show some indications that there was an impact there (you can see the marks on the outside but there's no caved in portion or something like that). There's also an area a few inches wide and maybe 18" long along the starboard chine about 3' ahead of the transom that sounds a bit hollow when hammered and also shows an elevated moisture content.
We found that the rest of the hull bottom is uniform and doesn't indicate the presence of elevated moisture nor does the transom.
So if I'm the first guy in the transmission scenario I'm looking at the hull and thinking "Oh, interesting, so I have an couple of areas I need to keep an eye on and ought to check them in the next year or two to see if they're changing". I say that because there's no indication on the boat that anything has weakened or is shifting with regard to spider cracks, pulled loose joints, breaking gel coat, etc and the surveyor has indicated in general that the hull looks good for its age and he feels like it will go for years and years without doing a thing. Would he take it 50 miles offshore...not likely (but he wouldn't take a CD22 there anyway). Would he cruise up the Inside Passage to Alaska...yes.
If T-Dog is the second (and I'm not saying that he is but he's on the buying end of this deal and has more at stake) he's thinking "Oh my, I don't want to get involved replacing the entire bottom on this boat". And if that's his thought process then it's his prerogative as he's the one laying out the cash in this case. He knows what his personal threshold for risk is and should stick to that if he's uncomfortable with the results of the survey. I'm using T-Dog here but of course this goes for anyone. So this is not a matter of me trying to persuade a reluctant buyer to overlook some "issues" and just go for it, not in the least. I'm quite sure there's quite a difference in our reaction to what news we've received so far: I'm thinking it's a 30 year old hull that's generally in better than average condition and has a couple of areas I might have to do something about some day and he's likely thinking about the check he'll have to write to get the boat and trying to ascertain whether or not it's worth the potential risk. And to my mind that's a good thing.
I'm pretty sure T-Dog's motivation was not to take me to task on the C-Brat web site but rather to try and gather more independent information that might allow him to make a decision. Where better to come than to the repository of all things C-Dory? If there had been someone here that could have spoken directly to problems (or not) with the bottoms of pre-1987 CD22's it might have been very helpful to him so I for one don't mind for a moment that he came here for that information. I wouldn't have minded reading about it myself.
I'm sorry for the wall of text above but those that know me know that I don't do succinct very well.
Bad trait perhaps but I got paid good money for too many years to stand up in front of a class and keep them going (and now I don't know how to stop!).
All the best,
Les
All the best,
Les
