Here is the product description, apparently you can calculate amp hours remaining from measured amp hours consumed...assuming of course, you know how many amp hours you had when you started. I assume with my two 60 amp hour house batteries in parallel I have 120 amp hours to use.
Description
Single and Dual Battery Bank Monitors
Provides Battery Status Information At-A-Glance
Link 10 (part#84-2016-01) and Link 20 (part#84-2020-00) use sophisticated microprocessor technology to provide complete battery status information for one and two battery banks, respectively. Simple and easy-to-use multicolor displays show volts, amps, amp hours consumed, and operating time remaining. The Link 10 and 20 allow you to select Automatic, Sleep and Scanning modes and automatically calculate and display charging efficiency. The Link 20 can monitor a house bank and starting bank or two house bank batteries at the same time. By adding an optional prescaler, Link 10 can monitor single battery banks up to 500 volts.
Product Features
* Digital Numeric Display - LED display shows numeric read out of volts, amps, amp-hours and time remaining
* Easy to read multi-color LED bar graph
* Splash proof panels allow for outdoor mounting and hands free operation
* Displays key historical battery information such as charge efficiency, deepest discharge, and average discharge
* Compatible with 12 and 24 volt DC systems
* Works with any battery type
* Includes DC shunt (part#84-2010-00 for Link 10 and 84-2011-00 for Link 20)
* Low battery alarm contacts
* One year warranty
Accessories
* Color-coded, twisted pair cable (eases installation). Available in 25 (part#84-2014-00) or 50 foot lengths (part#84-2015-00).
* Prescalers (0-100 or 0-500 volts) to extend voltage range covered by your meter
Not recommended for use with Xantrex MS or RS Inverter/Chargers
dogon dory":trmo33x5 said:
So what does the monitor measure to tell you how many amp hours you have?
