V-Berth condensation: foam
willronco
City/Region: Everett
Vessel Name: BREVITY
PostPosted: Sun Jan 26, 2014 4:26 pm    Post subject: V-Berth condensation: foam Reply with quote
Hello all!
We've begun fighting the good fight against v-berth condensation. I read through several VERY informative threads on condensation and have decided to start our fight with 1/4" thick closed cell (neoprene) foam:
http://www.amazon.com/Sponge-Neoprene-With-Adhesive-Thick/dp/B001G8E114/ref=pd_bxgy_hi_text_y
I have a sample of it at home, and it does indeed have an adhesive backing. Does anyone out there have experience with installing or removing it? I'm concerned that it either won't stick correctly and I'll be constantly fighting the foam peeling off the v-berth walls, or that it will stick so well that I'll never be able to remove it.
I welcome any advice or pointers!
Thanks, Will
PostPosted: Sun Jan 26, 2014 4:49 pm    Post subject: Reply with quote
A couple of comments:
1) I can't speak directly to the adhesive on that product, but I would use something like 202 Solvent Wash to de-wax the interior "walls" of the V-berth. Even though that is not the molded side of the gelcoat, I think there may have been some wax used in the curing process (and at least mold-release wax can easily still linger on a hull after years of immersion!). If you do this, use plenty of clean towels, as they recommend, plus proper protective gear (respirator, etc.).
2) How does the neoprene smell and do you dislike it? I mention that because the neoprene wetsuits, sprayskirts, etc. I have still smell "like neoprene" even years later. I sort of like the occasional whiff that means something like "Yes, going diving!" -- but not sure I would want to sleep next to it every night. Perhaps not all neoprene is the same in this.
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sun Jan 26, 2014 6:29 pm    Post subject: Reply with quote
I would suggest using a product specifically designed for marine applications such as FlexForm. http://upholsterysupplyonline.com/products/1601-Black-Flexform-Carpet-80%22-Wide.html
For adhesive us 3M 98 or higher, start at the top and work your way down. This stuff will stretch even around bolt heads and any uneven surface. More details in my photo album sub album man cave. http://www.c-brats.com/modules.php?set_albumName=album1789&op=modload&name=gallery&file=index&include=view_album.php
We cruise Prince William Sound from early April through the end of September; condensation is virtually nonexistent in the v-birth.
Boatless for now but looking
PostPosted: Sun Jan 26, 2014 7:01 pm    Post subject: Reply with quote
A number of years ago, a friend gave me enough 5/8 thick neoprene to do the entire interior of a 38 foot sailboat. (it would have been thousands of dollars, but this was left over from a commercial job, and could not be resold) We used a product which was similar, if not identical to the 3M 98 adhesive--and it worked very well. We also put in a very thin laminate, which was used on airplane interiors (courtesy of Douglas surplus shop). This made a great hull liner. However there was no problem with the odor of us: however it was almost a year before we cruised the boat after the application of the interior.
It seems that this 1/4" neoprene is going to be quite expensive, at about $25 a foot, 54" wide--I have never calculated how much it would cost. The carpet type as noted by breausaw is one option. I have used a closed cell PVC foam--I don't see it currently, but it was used by Bayliner in the past which was about 1/8" thick. There are also a number of other headliner materials, which also insulate. Most materials are $25 or less a yard, and some are as wide as 72".
When I had a black neoprene material, I wanted to face it--there are also number of other materials you can use for facing it, but that also will raise the cost.
If you go with this contact type of material, I would do several small area tests, including just the contact adhesive, and spraying the 3 M 98 on the surface, plus the adhesive on the back of the neoprene. I suspect that the latter will be your best choice.
PostPosted: Sun Jan 26, 2014 7:50 pm    Post subject: Reply with quote
You might look into an ensolite type product if you don't have the neoprene ordered already. I believe Armacell is one, but there are many. I have had fiberglass campers insulated with it (from the builder) and it had no odor. For the campers it was skinned over with a white vinyl type layer on the inside, but no-one re-doing theirs was able to find it with that skin anymore. However, people regularly painted the inside surface of the ensolite and reported success.
I agree that some sort of contact cement or similar spray would probably work well. I'm trying to remember what I used for the ensolite. It was "stronger" than the 3M 77... maybe it was the 98. It sprays out in sort of a "net" fashion and is like contact cement spray.
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sun Jan 26, 2014 10:43 pm    Post subject: Reply with quote
We are very pleased with this Sailrite product which is designed for marine application. We installed it in our V-Berth in about 2 hours.
http://www.c-brats.com/viewtopic.php?t=20833
PostPosted: Sun Jan 26, 2014 11:35 pm    Post subject: Reply with quote
The one thing that stops me from something like the Sailrite product is that I'm reasonably certain it is open-celled foam. Ensolite and similar are closed-cell (which I prefer on a boat). Which isn't to say that others might not really like the Sailrite product - just commenting on a possible difference from neoprene or ensolite type products.
Lucky Day
City/Region: Churchton
State or Province: MD
Vessel Name: Lucky Day
Photos: Lucky Day
PostPosted: Mon Jan 27, 2014 8:48 am    Post subject: Reply with quote
Sunbeam,
How about the short course for laymen on closed cell v. open cell?
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Mon Jan 27, 2014 10:44 am    Post subject: Reply with quote
Good point Sunbeam. I was originally looking for a closed cell, ensolite type product when we discovered the Sailrite stuff. My unscientific theory is that once the fiberglass hull is insulated, there is no longer a temperature differential for the moisture laden air to condense on. We have not experienced any v-berth moisture since installing it. I think that's why even a material like carpet that readily absorbs moisture can work well. The Sailrite material does have a vynal face on the interior side which makes it easy to keep clean.
PostPosted: Mon Jan 27, 2014 1:22 pm    Post subject: Reply with quote
Lucky Day wrote:
Sunbeam,
Quickie fill-in:
Closed cell foam has its air bubbles closed off from each other and also to the surrounding air. If you squeeze it, it doesn't compress much at all. Moisture cannot get into and out of it. Makes good life preservers, shock absorber material, and insulation gaskets, for example.
Open cell foam allows air to pass from air bubble/chamber to air bubble/chamber. Moisture can also move around in it. Compresses easily, since the air can vacate the cells. Makes a good sponge, but not a good life preserver!
These two materials also vary a lot in density and other properties (like heat insulation ability) based on the kind of rubber/plastic they're made of and how much air is entrained in them.
Hope this helps!
willronco
PostPosted: Mon Jan 27, 2014 1:24 pm    Post subject: Reply with quote
Thanks for the excellent tips and suggestions, everyone! I will be sure to try a couple of different kinds of foam and adhesive in small patches. Sure enough, the neoprene does smell like a wetsuit - I hadn't even considered that.
I've ordered a sample of ensolite foam and will test it for smelliness and adhesive-ness.
I'm also now considering an insulating paint such as Mascoat delta-t. Decisions, decisions! I'll keep the forum posted on any results I find!
Thanks again,
Will
Grazer
City/Region: Yukon
State or Province: YT
Vessel Name: C-Horse
Photos: Grazer
PostPosted: Mon Jan 27, 2014 1:42 pm    Post subject: Reply with quote
Sunbeam wrote:
... plus proper protective gear (respirator, etc.).
Sunbeam,
With all the different respirators out there, can you suggest one to use that is all purpose. I assume one would use a respirator with filters to protect against organic vapours (i.e. solvents, paints, contact cements etc.). Would this also double as a filtrate for dust particles from sanding fibreglass, uncured epoxy etc.? What is your preference?
Grazer
I'm still thinking about this, but I'm thinking a perfect insulation material for cabin walls might just have three or more layers to it:
Starting at the outermost layer next to the fiberglass and working inward:
1. Relatively thick closed cell foam for pure heat insulation.
2. A somewhat thinner layer of open cell foam to absorb and then release some moisture, giving the overall cabin a bit of resilliant / dynamic moisture control and sound insulation (sound insulation would be better with open cell foam). This layer would also absorb and then release odors, not a good feature near the galley or head, however.
3. A cleanable dressy layer of fabric to dress up the appearance of the insulation and allow for easy clean up in the long run.
Obviously, this concept will work out in different forms for a ritzy cabin cruiser versus a working commercial fishing boat!
(When I wake up in my Sea Ray looking at the headliner, I wonder at first whether I've met my final end and I'm boxed up inside a casket with all the trimmings on the door! Laughing
PostPosted: Mon Jan 27, 2014 2:52 pm    Post subject: Reply with quote
Good question and I fully support people interested in a respirator when working around boats Thumbs Up I can give you some information based on my experience. (Synopsis at bottom below asterisks.) Essentially, there two main types that I know of. One is "supplied air" and one is just "air you breathe in from the atmosphere through the filter." The former type are necessary for certain catalyzed paints (such as two part LPU's), but would be nice for anything. However they are more expensive and not as "limber" to move around in. I don't spray catalyzed two-part paints, so I have always used the "non supplied air" type and have no direct user experience with the supplied air type.
So, in the non-supplied-air type, there are the basic paper white masks. I don't use these so can't comment. Then moving up there are the semi-disposable types (they look like a "good" respirator but don't have replaceable cartridges). I used one of these at a job for occasional use (it was supplied to me) but didn't like the fit as much as my own (better) ones with the replaceable cartridges.
The next step up are the ones you can replace the cartridges on. These come in a variety of face-mask types, with various cartridges that you can fit (for various purposes) and parts that you can replace. There are half-face (cover mouth and nose) and full face (also cover your eyes). I really, really like the full face type for doing anything dusty, but, alas, I have a hard time finding one to fit, so I usually end up using my half-face one plus safety goggles, and enduring the "gap." I would prefer to use the full face one though. OTOH, if you are not doing a lot of things like sanding fiberglass overhead, the half face one is good, and easier to store, etc.
There are a few good brands. I look for ones wherein the face part comes in sizes (i.e. S, M, L), and I have spent a bit more for the better "rubber" in the mask part. A good basic respirator is the 3M 6000 series - my full face respirator is a 3M 6000 series. For my latest half-face respirator, I went up to the 3M 7500 which has a slightly better "rubber" face mask part. I used to have a different brand (Survivair, IIRC), and it was fine, but I ended up in more places that carried the 3M cartridges and parts, so I switched to using 3M respirators. You can see them here (or many other places):
http://www.envirosafetyproducts.com/3m-respirators.html
3M has filter selection guides that show you what to use for various hazards. I typically carry three different filters with me: The 6001 organic vapor cartridges (just plug into the respirator body) with the P-95 (dust) pre-filter (held on by a pair of retainers that you can re-use) And the 3M 2097 (plugs in and is used as a single filter) for tasks where they will be adequate (they are lighter weight and cooler to wear).
Once I had respirator(s) lying around (do be sure to store them such that they cannot "suck up" vapors in storage), I found myself using them for so many things. No more painting the living room while breathing fumes, for example, even though that's not supposed to be "dangerous." I'm sure it can't be healthy and it's more pleasant to not smell it (you can't smell the fumes if the respirator is working properly). Likewise for dusty work. I don't just use it for "special occasions."
So, upshot, I have a 3M 7500 half face respirator and a 3M 6000 series full face respirator. I carry the 6001 organic vapor cartridges with the P-95 pre-filters (and retainers), plus the 3M 2097 stand-alone filters. I also have a set of disposable clear face mask protectors for the full face mask (prevents scratches on clear view-through part of mask).
AstoriaDave
City/Region: Astoria
PostPosted: Mon Jan 27, 2014 4:17 pm    Post subject: Reply with quote
Thumbs Up On Sunbeam's treatise on protective masks. Most of us born pre 1950 probably inhaled more than a lifetime's worth of VOC from oil based paint before age 20, but we might as well protect whatever lung function is left. Smile As a longtime synthetic chemist, probably I have taken in five lifetimes worth.
The 3M 6001 / 7500 combination is likely a best buy combo for almost everybody. It is what I have been using the last ten years. Want to emphasize Sunbeam's caveat: seal the 6001 cartridges up inside a ziplop bag, minimum, between uses. Otherwise, they will slowly absorb organic vapors (aka VOC) and become useless.
A pro woodworker gave me a tip on checking to see if your cartridges are still working: spritz a shot of one of the citric scented cleaners ahead of your masked face, NOT into your face, and step into the cloud, inhaling normally. If you smell the citric scent, the cartridges are no good. Some VOC's do not have an odor pungent enough to smell, making it important to protect yourself even if you can not smell the fumes coming off any high VOC paint or solvent.
Probably many of us live in places where it is difficult to get hold of high VOC paint and are stuck with mainly water based coatings. I have been using System Three's two part WR-LPU for topsides and on dry sailed hulls for years, and have had good results.
Dave Kruger
Astoria, OR
Page generation time: 0.0545s (PHP: 65% - SQL: 35%) - SQL queries: 28 - GZIP disabled - Debug on
