- Joined
- Nov 2, 2003
- Messages
- 8,562
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Daydream
I love Coastal Explorer (a PC navigation program). I put Win 7 on my new Macbook Pro just so I could run CE. With the full set of NOAA and USACE electronic charts, it is awesome. Creating and editing waypoints and routes in CE is trivial.
I tolerate my C-80. The Navionics chart chips are the best cartography, but it is very difficult to do trip planning directly on the C-80, and the Raytech Planner program does not support the free electronic charts and is difficult to use.
Up to now, I have not found any way to get waypoint and routes created in CE into the C-80. I stumbled across this way on a cruising forum. It requires CE (or some other PC nav program that can export to the GPX file format), GPSBabel (a free download), Ratytech Planner (a free download) and a blank compact flash card. An overview of the steps: (1) create the waypoints / route in CE; (2) export from CE to a GPX format file; (3) convert the GPX file to a Raymarine Waypoints format file (file extension RWF) with GPSBabel; (4) import the RWF file into Raytech Planner; (5) export the waypoints / route to the file format required by the C-80 (file extension FHS); (6) copy the FHS file to the compact flash card; (7) import the FHS file from the compact flash card to the C-80. It is admittedly a workaround, but it is really easier to do than to describe, and really does not take a long time. The main limitation is in the RWF file, which has a limit of 50 waypoints. Here are the detailed directions (for any nav program, and using a C-70, but it all applies to CE and a C-80):
1. Save/Export from your nav program into one of the formats GPSBabel groks.
2. Fire up GPSBabelGUI
3. Select an appropriate input format
4. Select the file from step 1 as input file
5. Select an output format of Raymarine Waypoint File (.rwf)
6. The output file MUST be in the directory "C:\program files\Raymarine\Raymarine RayTech Navigator\Archive" but you can name it anything you want.
7. Check Waypoints and Routes boxes
8. Click "let's go"
OK, now we have to import this back into RayTech Navigator:
1. Start RayTech Navigator
2. Select File->Import/Export Routes And Waypoints
3. Select Import Routes and Waypoints
4. Select Import From File
5. Select Import From Raymarine Waypoint File
6. From the resulting list, select the file you saved in the previous section
7. Click OK
Don't forget to make it visible, as needed. OK, now we need to export this data back to the CF card:
1. Mount the card up on Windows
3. Select Export Routes and Waypoints
4. Select Export To Removable Card
5. Select Export To C/E-Series or A65 CF Card
6. Select Export All Routes And Waypoints (or select the ones you want)
7. Select the appropriate device for your CF card reader
8. Click OK
Now for the final step of importing the data back onto the C-Series:
1. Insert the CF card into the C70
2. Hit DATA button
3. Push ARCHIVE AND TRANSFER softkey
4. Push RETRIEVE FROM CARD softkey
5. From SELECT LIST select WPT or RTE
6. Push RETRIEVE ALL softkey (or group if you want)
7. Repeat steps 5+6 for other SELECT types
8. You'll have to resolve any conflicts for data that already exists on the chartplotter (by overwriting, ignoring, or adding a dupe)
9. Have a cold drink
8. Click "let's go"
7. Click OK
8. Click OK
2. Hit DATA button
