can't comment on this unit but will share a story regarding my last windlass system. it was installed in my 2000 carver 356 aft cabin. the windlass worked well, however the rode was all chain and when retrieving the anchor the chain would pile up in the anchor locker, to the point where it would actually stop the windlass from bringing in additional chain. when this occurred my first mate would go below and using a stick, knock the pile of chain down so i could bring in more chain, always happened at the most inopportune time. on another outing, water somehow got into the motor, messed up the electrical bushings and i had to hand crank 150' of chain. i would never do all chain again for several reason's, if you're anchored and the anchor gets stuck, good luck cutting the chain, second, i was anchored, out of the channel, a down bound barge experiencing steerage problems was being escorted by the uscg, with very little notice i was force to pull the anchor and move, like right now, fortunately, the anchor came right up, although i was prepared to cut and run if need be, (different boat than the carver, had rope for the rode). never forgot that situation. rope, for rode, for me!
good luck with your install
pat
ps: only good thing about having all that chain was great ballast for the bow!
