Capital Sea
Well, after jumping at the great deal for the V-1, I decided to go with a Delta 14 anchor and this required replacing the bow roller. I tried the Lewmar two roller model ending in 08 designed for the delta and this did not move the anchor out far enough so I could locate the windless just off center so the chain and line will run up the center line, without conflicting with the center cleat. So I am exchanging it with the 09 model which is 4" longer. This will give me a few extra inches between the swinging anchor and bow anyway and will solve the conflict. Not to mention that the extra reach will come in handy should I encounter a U-boat and need to ram it.
I have removed the stock bow roller and will make use of the forward center hole while I will need to fill the remaining two holes from the old roller and drill new ones. What are the issues regarding filling. I see some use epoxy. Will gelcoat set up will over epoxy or is it preferred that I use resin? The old holes will be under the stainless base of the new roller and all of that will be sealed, but I want to do things right, so a little advice would be much appreciated.
Also, when I cut the two larger holes for the windless, 2" each I think, some say I should make the holes slightly larger than required so I can seal the edges. What is the best, short of overkill, method for sealing the raw edges these holes.
Last, for now, the windless will sit partly on the textured surface and partly on the lower smooth surface on the bow's center line. How does one create a flat surface upon which the gasket and windless will be mounted? Once I cut the holes and can set the top part of the unit into the holes, I expect that the elevations will prove to be such that if I snug up the mounting bolts which run through the raised textured area that the super marine white stuff between the lower area and the windless frame/gasket will harden at the textured areas elevation. Is this the method?
While I wait for parts, I wave installed an led reading lamp and modified the dinette bed to create a comfortable reading couch using the rigid center cushion from the V-birth. Photos to follow.
