Adeline-
For those interested in your set-up, could you tell us:
1. if there are any manufacturer's name / and or model numbers on the cross-connector rod, and
2. what the black fitting is on the front of the kicker and its function?
One can see the ball joints at either end of the rod along with the length adjustment threads at the kicker end, but I can't quite see if the black casting (?) at the kicker end has any other function other than to serve to attach to the front of the kicker steering bracket and move the ball-joint attachment point out conveniently in front of the engine.
Chris-
I know we've discussed some of these systems before, and by putting "steering rod" and similar topics in the Search function a lot of discussions should pop up. Also try looking in the Library under Motor Control Systems for topics on the subject.
Cabela's makes a front mounted connecting rod that many have found very useful.
Others have designed and built their own. The traditional rear coupled steering bars are also popular.
Which system works best for you will be largely determined by the exact combination of main engine, kicker, existing steering set up, and intended uses for the kicker. There's a lot to consider and sort through! Joe.
