What length shaft on 83 Angler 22
alleuro
bought an 83 Angler without a motor do I need a 21" shaft or 25" I understand that. there is some movement available via how it is mounted. What gives the best performance?
Take a tape measure, go to back of boat, measure from top of transom to bottom of hull. Your tape says 20" Buy motor to fit transom height. When you install the motor bottom of hull should be in line with bottom of cavitation plate on motor. There will be holes / slots on engine bracket for adjustment. A 25" shaft will be 5" too deep for your boat, unless you built a transom adaptor/spacer to raise it up
:beer :mrgreen:
