Lynn Marie
- Joined
- Oct 30, 2003
- Messages
- 440
- Reaction score
- 0
- C Dory Year
- 1997
- C Dory Model
- 22 Cruiser
I have one more spot that should also be checked out if you have the Wallas and that is the elbowed thru hull for the exhaust. You may be getting a leak in heavy weather when the boat rolls from side to side. I finally slowed the thing down by removing the fitting and re-installing with a layer of high temp teflon sealant cord I got from the Gizmo King, TyBoo Mike. Since the Wallas does get hot you need to use some type sealant that will take the heat. Not sure what the factory uses but that would also be a good source if resetting is needed.
Tim
Tim
