That's true, but as Bob states the Wallas stoves are usually wired directly to a battery as that's the stated requirement in the Wallas stove manual. The reason for this is that the stoves have a program for shut down that runs for several minutes after the stove is turned off a the switch. Wallas wants to assure that the cool down/shut down cycle runs regardless of what boat owners do with the battery switch. Also as an aside, there's often an inline fuse in the wire connecting the Wallas to the battery. But otherwise, I generally agree that there is no standard wiring scheme on our boats.Chester":2b7wb6rm said:There is no standard wiring scheme on our boats, Martin. You'll have to figure yours out. You should not need to use more than one battery to start the Wallas though.
Adeline":2mhqfddw said:Wallas Stoves like healthy voltage, no doubt.
Here's one...how are you going to start that great big motor if you wake up with dead batteries ? :cry
A rope ??
When it's cold ???
Good luck ! :?
Good plan - I run mine every month or so for 30-60 mins. Scan Marine recommends that you use it frequently to keep it in good working order also.bridma":2leioo3j said:I must admit I have been negligent in using my Wallas. I do not use it much for heat as we are usually warm weather cruisers. When at a dock or at anchor I tend to use a portable one burner butane stove if making a cup of coffee or pot of soup, it just seems quicker. When underway, we always use the Wallas, it's safer.
I fired up the Wallas yesterday, only the second time since August! It worked perfectly. But that is not good practise. A Wallas needs to be "hot & happy". So from now on I am going to fire up the Wallas a minimum of once a month for 30 minutes.
Martin.
