- Joined
- Mar 3, 2005
- Messages
- 3,599
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBD
- Vessel Name
- journey on
OK, Here's my take on the Wallis 95 stove. We bought Journey On in '05 and it came with said stove, for about $2000. Judy loved it at first sight, since she'd spent a summer in Alaska with no heat. It worked well for 5 summers, though it's not the perfect stove/heater. Note that this is the model 95, not the 85. For the conclusions, skip to the Conclusions, unless you're Pat Anderson, who'll want to read the whole sorrowful story.
To summarize, we used it during the summer from '05 to '11 during our cruises. It started, gave heat and shut down for a total period of operation of 18 mos. I used either expensive kerosene or even more expensive Kleen Heat. Never diesel. Judy started it on the high setting and shut it down on high. The heater option only blows air across the cabin, so we got an Ecco Fan, which can blow air towards the V-berth, though neither fan got any air into the V-berth.
When we were at a dock, we used electric heat so the Wallis was rarely running all night. For the morning cup of coffee, Judy got a Korean butane stove, since the Wallis is slow to start and shut down. My opinion is that the Wallis stove was used lightly for those 6 years and treated nicely.
Suddenly last summer ('11) the heater blower fan didn't start, and by golly we we weren't at a dock and it was cold. So a call to Scan Marine and a nice conversation with Mike led us to the failed blower switch, with a recommendation to drop off the stove for cleaning and a new switch. We didn't drop off the stove on the trip south for various reasons and that simple act led to the comments provided below.
Conclusions
I'm putting my conclusions here so that they'll get read.
First, the Wallas Model 95D is a crappy design as far as reliability and service go, and the detail is below in The Story..
Second, it's what we have and here's how to deal with that.
-----I would use filtered kerosene and/or Kleen Heat. They are clean fuels that doesn't gell or get bugs. We have only used that and our stove is squeaky clean. Always start/stop the stove on “High.”
-----Get a Korean stove (<$20) which runs on butane cylinders ($2) for when the Wallas dies, and it may never die.
-----Perform no service cleaning, etc on the Wallas, that's just looking for trouble.
-----I would wait until it quits working and then send it back to Scan Marine.
---------------Learn what's wrong and get an estimate and then either:
-------------------pay the money and pray
-------------------or, let them keep the stove, install a Webast/Espar forced air heater and a propane stove.
The Webasto probably costs $1200, and the propane stove could be done for $800 using a 2 gal outside tank. Installation is up to you. Either way, it's cheaper than a new Wallas, and you have forced air heating and a easy to use stove.
Note that Scan Marine feels that all of these problems have been solved with the Model 85. I don't know, that's not what we have.
The Story
Now, let it be said here that my conversations and dealings with Scan Marine have always been courteous and helpful. Remember, they're just dealing with what they sold, and they're decent people. I may have lost it a time or two, but then they're selling, I'm buying/fixing/replacing.
When we got home (SoCal) I pulled the stove out, removed the heater blower switch mother board and started down the slippery slope of maintaining the Model 95 Wallas stove. Scan Marine pointed out that not only does the stove need cleaning, but several parts need replacement on a regular basis. Being a bold sort, I thought “I can do that, and learn something.” And I did.
So what did I learn? First the Wallas Model 95 is a terrible design from a reliability and maintenance standpoint. And second, don't work on that thing yourself, since there are a lot of unique procedures that you learn about the hard way. Scan Marine has learned and I'll bet it was the hard way, through a variety of stoves. Let us go through the list of design issues on the Model 95.
First the heater blower switch. That switch is on a motherboard which get inundated with water, soap and grease, so the motherboard corrodes. The switch is OK, just not connected to anything. And obviously it corroded in <20 mos of use, so it's a replaceable item. For $125.
Second, Scan marine says that there are replaceable maintenance items as follows: the igniter, the burner mat and the stove blower motor. They also said that's stamped on every owners manual. Couldn't find it on mine, but OK. Ordered those parts, read the C-Brat document on changing the stuff and went to work.
Disassembled the burner to change out the parts and clean it. The burner looked great, no cleaning needed. Fuel supply tube clean as a whistle, kerosene is a great clean fuel. Replaced the igniter and mat (cut your own mat from fiberglass cloth, save money).
Moved on to the motor replacement. That didn't go so well. First, that motor is buried in the innards of the stove. You remove everything to get to it. Second, the Model 95 has 3 motherboards, all plugged together with various hard to remove plugs. You need to remove 2 of them. And it all needs to be removed. And third, that motor is a cheap $3 part from Mubuchi/Japan, which is a bad part to bury in a stove. And fourth, the position of the fan on the motor shaft is critical and must be checked with the stove in operating position.
So I replaced the motor, reassembled the stove, installed it and turned it on. Got a rattling noise from the fan as soon as the stove got hot. Talked to Mike/Scan, pulled the stove, reset the fan, reassembled the stove, replaced it into the boat, still got the noise. Tried adjusting the fan on the shaft while the stove was still in the boat started it, the fan was nosier, shut down the stove, took a long time, pulled the power plug and there was my MAJOR mistake: never, never, never pull the power plug on a Wallas stove while the red light is on. Turns out another design flaw is that the Model 95 electronics do not have a reset to an initial state. Talked to Mike/Scan again, tried his fix, didn't work.
Finally sent the stove back to Scan marine and got it back for $125 plus shipping. Installed it, the noise appeared when the stove got hot, shut the stove down, restarted it and it now appears to be working. We'll try it this summer.
Please read my conclusions above.
Conclusions
The Story
