Thought I'd add my installation and initial opinions on the Wallas 1300dt...
Last spring, Greg and Cindie gave me a demo of their 1300 on a crisp evening at Jones island. The way it heated up the entire cabin of their 19, PLUS their large camperback enclosure convinced me it was exactly what I was looking for. So, this Thursday I finally made the call to Scan Marine to place the order. The kit arrived on Friday and I installed it on Saturday.
It took about 2 hours just sitting in the boat trying to decide where to put it, while reviewing the great ideas in this thread and others, along with the installation manual. There are several design constraints, such as the tank must be below the heater, the intake/exhaust duct can't be longer than 3', and the warm air duct, if used, can't be longer than 3'. Also, the exhaust/intake must be at least 1' above waterline, and behind the widest part of the boat (this according to Scan Marine, although I didn't see any mention of this in the manual).
Confounding those restrictions was my preference to have it enclosed and out of the way, so as not to take up counter space (as in the case of a countertop installation) or legroom (in the case of an under-table installation). Additionally, I found myself really reluctant to drill unnecessary holes into the hull, countertop, fiberglass cabinet, or any other finished/exterior fiberglass area.
So the compromise I decided on was to mount it to the drawer frame under the galley counter and to not use the air duct (it was not recommended by Scan Marine for this model anyway), and this just requires the rightside cabinet door be left open while in use, which isn't an issue for me. My other thought with this location is that if I decide to relocate it down the road and use the air duct, it wouldn't be a big deal to do that.
After deciding on the location, it took about 4 hours for the physical install, mounting the heater, cutting and installing the thru-hull, cutting the intake and exhaust ducting to proper length, installing the tank. Then it took about 2 more hours to install /route the 12v wiring, fuse, and the optional remote switch.
Up until now, my winter boating has been restricted to marinas where I can plug in and use a 1500W ceramic heater. That heater has 2 settings 750W and 1500W, and I usually run it at the low setting and occasionally bump it up to the high setting for maybe up to an hour before I get too hot even in the coldest weather (about 32 degrees F is my boating limit)...
After running the Wallas for about 4 hours Saturday night, a cold night in the low 30s, I would say that it is somewhere in between the low and high setting of my ceramic heater, which is perfect! Although I don't have a thermometer yet, I would guess that it maintained around 70 degrees in the cabin. It is also much quieter than the electric heater. On the return trip Sunday morning I ran the Wallas, and it was so nice to finally have a warm cabin while cruising, and without fogging in the rain and snow. Back at the marina, it was also nice to be able to turn on the heat while cleaning up the boat on the workstand, without having to get out the extension cord and electric heater.
A couple of photos of the unit and the optional remote switch.
There are a few more photos in this album:
http://www.c-brats.com/modules.php?...ame=gallery&file=index&include=view_album.php
