Aside from the ensuing discussion of the virtues of the e-tech motors from Evinrude, I'd like to go back and point out
1. The video's narator, Karl Sandstrom, is the e-tech Project Manager for Evinrude.
2. The video's origin is a person that goes by the handle of "Screamandfly". His profile says he has produced 15 videos for Youtube and lists his age as 106. (In
Dusty's bracket, or thereabouts!) All the other videos (that I watched) are of high speed boats running wide-open (one clocks 113 mph on the GPS). Is this guy an amature or a pro who works for Mercury? Is it Karl himself?
3. Dave (Oldgrowth) points out above that we don't really know for sure if both motors are propped equally, and the Merc gets a headstart. So much for a fair test. A difference of 2-4 inches of prop pitch could be like putting one truck in 2nd gear and the other in 1st.
4. Outboard motors are certified by the ABYC or something like that to have the horsepower as certified. They can be + or - 10% of that figure.
A 150 hp motor could actually show anything from 135-165 hp on the dynomometer or however it is measured.
5. Most motors are offered in three or more versions where the same basic block is offered in three horsepower configurations, such as 75, 90, and 115. The smaller motor should have more torque proportionately, and may produce substatially more hp than it is rated, as noted above. By carefully picking the motor in one manufacturer's line to match up favorably with that in another's, a substantial advantage could be achieved, where your underrated motor was matched against the competitor's maxed out model.
6. Individual motors coming off an assembly line vary as much as 15-20% in power produced when tested. Often this differential cannot be accounted for when examined, such as when looking for differences in fuel mixtures, ignition timing, etc. Some think certain motors just happen to have better balance than most. If you were going to do the test above, would you select your best one after testing?
7. The video and test were obviously made to prove that the e-tech was a stronger motor than the Yamaha. How many factors did they hedge on to get the results they did, and do you think they would have posted it if the results were different? Of course not! Consider the motivation, then try to decide just how fair they might have been.
Just some thoughts to consider.................Joe.
