I had a max power pot puller which is similar to the ace puller
I had it attached to the 1026 mount which ace recommends for use. Several boats In valdez have them attached to their ace puller or similar ones
Was pulling string of 2 pots Wednesday, it broke off in the Scotty mount an could not catch it in time. Called Scotty, they said sorry but that product is only recommended for their diwnriggers and their pot puller. So I’m out cost of Scotty product and pot puller
If you are using the swivel pedestal mount with a pot puller you are s—-t out of luck. I have looked at several googled sights that show photos of pot pullers on this mount
So I’m done with Scotty products and if if you use this product , use at your risk. So I screwed up by believing the folks at ace and on different forums who use them. I should have known better.
