duckman
- Joined
- Apr 18, 2006
- Messages
- 11
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Vessel Name
- no name yet
After taking in the outboard because of a stalling problem I was informed that the four carbs were cleaned...but when the top plug was pulled it had no affect on the rpm. The plug was firing. The mechanic was not happy with this, was not sure why and suggested taking it out and running it with some Yamaha ring cleaner. Except for a slight, very slight hestation at 1800 rpm the motor ran well full throttle getting up to 5100 rpm in choppy water.
My question is... would I even get to 5100 rpm if the top cylinder did not appear to be contributing when at 2000 rpm in drive with the earmuffs on?
Full power range according manual is 5000-6000 rpm.
The mechanic is certified for Honda and comes highly recommended by two state agencies...so I have confidence in him. He says openly that Honda carbs (four stroke) can be real beasts and sees way too many problems with them.
Thanks...I would appreciate any insight I can get.
Frank
Frank
