T.R. Bauer
- Joined
- Nov 17, 2007
- Messages
- 1,808
- Reaction score
- 1
- C Dory Year
- 1993
- C Dory Model
- 22 Cruiser
- Vessel Name
- C-Whisperer
Do you really have to have them. I have heard both.
Sea Wolf":w0cch2tw said:The reasons for two batteries on twins are two:
1. Redundancy, so that you have a start battery for each engine, and if one goes dead, you can start the other.
2. Each motor has it's own alternator and regulator. If connected to the same battery, they sense each other's high charging voltage, think the battery is fully charged, then stop charging, then sense the now low voltage, and then start over to charge, etc., ad infinitum, in a cycle. (This may not exactly describe the events, but you get the idea!)
Joe. :teeth :thup
jlastofka":bm9qzq1h said:You don't HAVE to have twin batteries, but having a spare is a good idea. Having an A/B switch to select either or both at the same time is good, so you can select between "good" battery and "dead" battery if needed.
Some alternators can be damaged if you disconnect the battery while the engine is running. Having a "make before break" switch and never selecting the "off" position while running will keep that from happening. The other kind of switch will go open as you go from A to B, but the make before break switch will momentarily go to "Both" while going from A to B.
Just don't get careless and select "off" with an engine running.
I run my #1 battery on odd days and the #2 battery on even days. It helps me remember to even out the use. Sometimes I run "both" for charging, but usually just one or the other. If I'm overnighting, at night I'll select the one that will be run the next day so it gets recharged after use overnight.
With two batteries and a switch you have an extra battery in case one dies, and it's easy to "move" the battery between engines in case one engine isn't running/charging and you're limping home on the other engine. Having an extra "house" battery would be nice, but these little boats are sensitive to extra weight, and there aren't many things heavier than batteries. It's your call regarding the tradeoff.
Most everyone agrees, though, that having at least two is an important safety factor. And a switch to isolate one or the other is important, too. With the engine(s) off, and your lights on, switch SLOWLY from A to B and see if the lights flicker, which would indicate a non-"make before break" switch, and danger to the alternator(s).
I have the make before break switch and I still don't like to switch with an engine running.....
jlastofka":s03mzjhd said:Hey, Joe, as an aside, how come your crest on the left shows three granny knots instead of three square knots? Is there a history of "challenged" knot tiers in the family? :wink
Jeff
