Trim tab question
Spike38
Still fooling around at the drawingboard. Current thinking is that if portapotti's a major problem for us we can find out much cheaper in a 22 than a 23. So we're looking at a used 22 without trim tabs. Question: How essential are trim tabs considered to be? Especially to someone completely new to C-Dorys (if that makes a difference).
I would not recommend owning the 22' cdory cruiser without trim tabs. In my opinion, trim tabs are a must.
You could always have the trim tabs added if you purchase a boat without them.
Good luck in you hunt
The Duck has trim tabs and a permatrim copy (bobs machine shop) also a 90hp suzuki with over 3yrs left on warranty with s/s prop and all suzuki gauges
comes with all the goodies windlass , gps, auto pilot ,pressure water inside and out , floorboards, bimini top , front opening window ,swimstep ,privacy curtains, two batteries with switch and solar battery collectors 115 volt shore power with gfci
with a 07 galv. single axcel trailer with brakes and guide posts.
The only option maybe you would want is refergerator .$31,500 obo
come on down to sunny Naples about 1 hour from punta gorda and take a ride you wont be disppointed Jim on Duck
btw you can buy the boat with or without trl and I will deliver 239-269-9537
They are not Mandatory. But once you ride in a 22 C-Dory with them they will become Mandatory!! :mrgreen: :beer
If you travel almost exclusively on flat water inland lakes and have very even lateral loading of the boat (persons, gear) they are not essential.
But in frequent chop, and especially if your ballast (persons, gear) cannot be moved easily, they are invaluable.
A hydrofoil on the motor can deal largely with bow down trim for chop, but side to side (lateral) trim requires tabs.
Joe. :teeth :thup
