Jack in Alaska
- Joined
- Aug 17, 2004
- Messages
- 1,192
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 26 Pro Angler
- Hull Identification Number
- CD026021I405
- Vessel Name
- HIGH TIDE II
First.......This is in no way a manufacturing quality problem but caused by stupid. I write this only as a FYI.
Our friends have a 22' Classic C-dory exactly like ours, same year 1983.
Recently he noticed that his 100 hp. Yamaha was doing too much flexing while underway. Upon inspection the top of the transom fiberglass was found to be cracked open for about 6". It was caused when the motor was installed 5 years ago and was tightened to much crushing the top of the transom and causing the crack. It allowed water into the transom and over a period of time the wood rotted and lost all strength.
I am not all that convinced that the motor tightness could crush a solid transom so maybe it happened earlier and the motor just amplified it.
The motor is off, transom top cut loose and it will be rebuilt/fiberglassed as needed.
It is right in the middle of our king salmon season and they are losing out this year.
Check any openings into your fiberglass to make sure they are sealed up tight and look for and repair quickly any cracks etc. found in theglass.
