Tug
Active member
- Joined
- Jun 22, 2007
- Messages
- 1,006
- Reaction score
- 9
- C Dory Year
- 1985
- C Dory Model
- 22 Angler
- Hull Identification Number
- DOR22241H585
- Vessel Name
- Drifter
It seems that i am having the same problems with my newly installed AirMar P66 transducer as i did with the last transducer i had on my boat.. I am wondering if the problem is because the transducer is mounted on the Port side. The problem is that i loss the signal when i trim the motor up to the point where the boat is running at optimal plane and RPM.If i trim down to a point where i feel the boat is dragging a bit i regain the transducer signal. Another annoying thing is that i can be be anchored,i have the bottom, i bring up the anchor and slowly move off at trolling speed and suddenly i loss signal again. I can continue to proceed at trolling speed for a minute or two before i acquire the signal again.The flat hull of the C-Dory creates a lot of turbulence and that may be part of the problem.The transducer was installed as per instructions, for those who have installed the Airmar P66 transducer on their C-Dorys do you remember if you used the wedge. ( shim ) that came with the transducer.I plan on moving the P66 to the Starboard side but that may not be the solution to this problem. Tug
