- Joined
- Sep 30, 2006
- Messages
- 4,673
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Vessel Name
- 'Au Kai (Ocean Traveler)
I have finally gotten my transducer to go with the Garmin 740S. I read the install instructions and went outside to do some measuring etc. I have a few questions, however, and I want to make sure of WTH I'm doing before I break out the drill. :crook
http://www.c-brats.com/modules.php?...ame=gallery&file=index&include=view_photo.php
I am limited on how far center-line I can mount it due to the bunk on the trailer. See the pic. The instructions say that it should have smooth water flow over it (makes sense) and be as centered as possible. Is this position adequate? Will the trim tab affect the reading? Should I go more towards the engine, which would mean cutting the bunk? (which I really don't want to do)
Finally, my long range plan is to remove the swim platform from the current starboard position and move it to port. That way I can mount my kicker on the starboard side. The reason; when using it @ it's current location you have to step OVER all the controls, cables etc. It makes more sense to me to not have those obstacles in the way. Will putting a kicker on the same side as the transducer [later] mess with the function/readings?
More pics w/ measurements in my album. Thanks!! (as usual)
