Towed the 22 after 4 months storage. Inflated the tires to 50 PSI cold. Ambient air was 40F. Boat has normal load, full fuel tanks, empty water tank, all the usual gear. There was a perceptable increase in the resistance of the package being towed. Running on the same route, the truck had to be shifted into lower gears to make the climbs. Let off the gas and an immediate reduction in speed. Fuel consumption was above normal. Hubs felt cool, brakes seemed normal. What is likely to be the problem?
Sticking caliper?
Stiff waterproof grease ?
Axle out of alignment?
Your dianosis is appreciated.
Mike "Levity"
Sticking caliper?
Mike "Levity"
