topping off fuel tanks?
Some fond memories flying out of Otis field in the late 40's!!
Dusty
The reason I use high test is that many articles I have read indicate that it stores better than regular gas. I have a Honda 90. I do not know if it runs hotter on high test , but it seems to work purrfectly.
Fred, Pat and Mr. Grey
Sawdust,
I was stationed at Otis in 1967.
That was the year the Red Sox went to the World Series with Yaz, Lomborg, etc.
Being a diehard Yankee fan from NY, it was the only year I rooted for the Sawks. Self preservation came to mind. :lol:
Allan
Interesting arguments for and against cruising with full fuel. I too cruise with just the fuel I need with reserve, I do not keep the tanks full. In a Tomcat, this may be a bigger deal than with the other models. Full fuel adds 900lbs to the boat and it is a waste to push this weight around if you're going 50 miles.
In terms of fuel, I sure wish there was a way to use a stick instead of a gauge. My gauges only show about a 30 G delta from "E" to "F" (each tank carries 75 G).
The J.C.Lately is a late '06 CD-22 with (purportedly) 25 gal PE tanks. Does anyone have any recommendations regarding how much of that is actually convertible to "go"? I can't believe a system using pickup tubes actually gets all the juice out of the tanks.
Paul Priest
Sequim
Paul Priest
Sequim
Paul-
I can't answer the capacity question, someone who ihas run one down and then refilled it would have to answer. However, on the older 18 gallon Mollner tanks on the earlier CD-22s. the tube length varied a lot from boat to boat, with some folks getting 17.3 gallons and others more like 15. Just depended on who cut and made the pick up tubes up, apparently.
Also, you wouldn't want to go right to the bottom of the tank where all the water and crud accumulates, anyway.
I siphon out the bottom of my tanks every year to clear out as much accumulation as I can get out of them.
Joe. :teeth :thup
Joe,
Another school of thought-if your pick-up tubes are right on the bottom you will be sucking up and filtering any crud as it accumulates and before it can build up to create a problem? My old tanks (2002) had a curved plastic tube for a pick-up, which put the screened end right along the inboard bottom edge of the tank. Although I never ran them anywhere near dry, logic would indicate that almost every bit of fuel could be used. I never had a fuel related problem with the system until one of the tanks cracked.
ppriest":212jxzwa said:
The J.C.Lately .. Does anyone have any recommendations regarding how much of that is actually convertible to "go"? I can't believe a system using pickup tubes actually gets all the juice out of the tanks....
I just bought an 07 CD22 with the 25 gal tanks. I spent the week-end doing the break-in. I ran the port tank until the engine stopped. As best as I can tell there is still about one gal still in the tank. I think it would still pick up some if I ran as idle speed.
The only time you have too much gas is when you're on fire. :lol:
Can I replace my 20 gallon tanks with the new 25 gallon ones? Are they just wider or what?
Rick
Rick,
I just replaced my tanks because one of them cracked. New tanks are 23 gal and are about 2 in lower in height because they are designed to fit on the new molded floor which is higher. They are also about 2-3 in wider, so the center gap under the splashwell will be about 6 in narrower. I elevated my tanks about an inch on wooden strips thinking the old fill and vent hoses would reach ok-but the location was off just enough that I had to replace both fill and vent hoses. I know the factory advertises 25 gal tanks but here is the molded tank label on my tanks:
Paul -J.C.Lately
I have twin 25 gallon tanks on my 2006 22C-Dory. My engine sputters out and I switch tanks. I fill up with 23 gallons. I have put 24 + galllons in it but don't want any fuel spills.
Allan
I top off my tanks after each trip, usually 25 to 40 gallons depending on the trip. For extended trips I take along 2 extra 5 gal jugs. I pulled my boat up from Seattle with ¾ full tanks; I see no problem keeping them full. The way prices keep going up it makes sense to top them off each time.
With out fail I usually fill until the breather sprays a little out, then slowly add tell the tank is visibly full.
I hate having to stop for gas when we are heading out, seems to hurt less when I fill her up after a trip.
About $40 diesel round trip to launch
$20 for the tunnel pass
$30 to $40 for parking
Paid $120 seasonal launch fee so hopefully 10 trips will = $12 a launch
Average about $125 in gas each trip
So I guess it casts us around $250 to $300 each time we go out, and it’s worth every penny.
Deep water bay, Prince William Sound Alaska
Haven't found the big flat fish but these taste great!
And it isn't all about fishing...
