Most fuel suppliers will change to a winter diesel when it starts getting cold. ...at about 5 to -10 degrees, wax crystals start forming (depending on the blend) and screwing things up. If you're truckin around in the Bite arse cold zone (say 10 and below), some additive would be good. I worked one, and only one, winter in WY where the temp was stuck at about -30ish and some of the big rigs where having troubles with fuel systems, around the P.N.W it doesn't really get cold enough for that ugly wax buildup to be much of an issue. IF you don't drive the diesel tow rig much, you might add an anti biocide to keep critters from growing in your tank (if your fuel sits for much over six months)
my $0.02
