TC 255 Trailer, How "Slick" should it be?
Nov 3, 2003
7,313
2
2005
22 Cruiser
Hull Identification Number
CDO22289L405
Captain's Choice II
When I bought Captain's Cat, the former owner had it on the trailer. Launching for Sea Trial was easy, it slid/floated off fine. Getting it back on was another story, don't know if the ramp was a little steep but he could only get it so far up on the trailer and a tremendous amount of "winching" only brought it to within 2' or so of the "home" position. He actually brought it out of the water, on a level surface and tried winching some more. Then, :shock: he got back in his truck, moved smartly forward and slammed on the brakes. That did the trick! :roll:
The only thing I have done since then is launch it but now I need to get it back on the trailer and do the electronics installs I have to do and put in the A/C which requires a hull penetration. I could do it on my lift but it'd be awkward. I bought a bunch (!!) of THESE, and mounted two at the stern of the hull bunks.
Before I do any more, I thought I'd ask the audience, how many should I do? I have enough to do the whole darn thing (told you I bought a bunch) but don't want it sliding off on the road :cry (Yes, I do tie it down securely before I travel :thup ) nor do I want it to go all the way up the trailer when I put it on in the water and end up in the truck bed! :smilep
Here's three pictures, you can see the set I've mounted so far on the stern of the trailer, I put them side by side, about 1/2" apart. Sorry for the haziness of the last one, Sally wouldn't let me open the window...
What are your opinions. C'mon, don't be shy! :teeth
Charlie,
I know very little about the subtleties of loading/unloading the Tom Cat, but many owners have apparently resolved to a usable configuration and will chime in. But why aren't you putting the slick sticks at the 'front' end of the trailer (i.e. at the V section of the bunks) where all the weight and friction is during loading/unloading? The rear shouldn't even be touching the boat while floating on/off. My 2c.
Good point Steve, hadn't thought about that. The only two sections I've put in so far are the ones you see in the pix. Before I did any more, I wanted to ask the question....
I have enough to do the whole shebang but maybe the only place I need them is up at the "Vee" section fo the trailer? Dr Bob? Dr. John? You guys must be still in the sack or out on a "house call"!! :lol: :lol:
"Great works are performed not by strength, but perseverance" (Samuel Johnson) And hopefully by Slicks too!! :wink:
Charlie,
You didn't mention it but I always back the trailer in far enough initially to get the complete bunk wet. Then pull back up to the proper loading point. The wet carpet makes it much easier to slide the boat up to the winch.
Thanks Ken. I'll see if I can do that. The bunks on this are pretty high off the ground and I'm afraid that, unless the ramp is pretty steep, my exhausts on the truck would be underwater :cry if I got the front of the bunks wet! Maybe not though....
Charlie,
Our EZ Loader trailer bunks are entirely covered with a slick mat, front to rear. When wet, the boat can be winched on by hand,(OOF!). What I have started doing instead of getting the truck rear brakes wet is restarting the engines and nudging the boat all the way home with the throttles. Tighten up the winch and then gently bump it the final inch in the parking lot with the brakes.
Don't worry about the exhaust being in the water, it's the brakes that don't need any salt water in them.
Launching with the slick bunks goes easily if you just tap the brakes when you see the anchor start to move lower. Safety chain is removed at the last second by the crew with an 1/8" trip line.
Hope some of this makes sense and helps. All the best,
Thanks Roger, it does! Did you use THESE
or something else? Are they screwed on? And, did you cover the v portion forward too and the entire width of the aft bunks?
Thanks!
I don't have a cat but judging by the crease in the fabric on those bunks I'm wondering if it's a good idea to have all the boats weight sitting on plastic strips rather than the softer fabric. I've thought about using something similar for my 22 but since it's not a cat the weight would be distributed more evenly. That would be my only concern about the cat and the strips. Also, you put a gap between the strips. Wouldn't the "pontoon's" edge go between them rather than sit on top? Anyway, I feel your pain as the 22' is a bear at times to get winched all the way forward. Might have to try the brake technique
Yes, there's a little "v" at the back, very shallow but a "v" nevertheless. I put the strips on either side of that so the "v" would rest in the cavity. Hopefully assist in centering although with the tunnel and that big hump in the middle of the trailer, I don't think it will be a problem! If I have a lot of strips, I think the weight will be distributed pretty well across all of them. They're pretty substantial. Still thinking about it, thanks to all for the advice!
What about "liquid rollers" or silicone spray?? (keep it simple!) :idea
Charlie,
Here's a short length of the EZ Loader bunk cover.
We considered this problem when be had our float on trailer built (supervised by Wefing's--Marc has a not of experience with other cats).
We have 8 feet of slick on the front of the bunks, and this works very well. We power on and off--little winching needed.
I would also consider putting the full width bow brace. The single pedistal is probably not enough to restrain the boat in an emergency stop. Yes, we do chain down foreward, and put the strap over the cockpit, in front of the cleats, so that it would restrain the boat from going foreward in an emergency stop.
We purchased an electric winch, but it turns out that the hand winch is fine--just to tighten up the boat.
I agree, that the aft part of the boat is floating as you load. What we have works well.
Thanks all. I'll let you know what I do, and how it works out!. May just decide to use a CH-46 and drop it on vertically! :shock:
