I have two rocker switch panels on the dash of my (new to me) 1988 22 Cruiser. There is a vertical row of red fuse buttons on each panel that can be pressed in. What does this actually do? The back of the panels have all these "fuses" soldered to a common bus. Are there actually fuses here? I ask because my Nav lights don't work and I want to check if fuse is bad. Is the fuse on the switch panel itself? How do you get it out?
