Hi there,
I'm planning to change oil in my twins DF140s this afternoon and having a bit of a debate with my buddies. We hauled the boat out last weekend and its been on the trailer with the engines verticle. Should I start the engines to reduce viscosity prior to draining or just drain it cold? The working theory on the later is to prevent the oil from distributing thus allowing an easier and more complete drain.
The outside temp will be in the 70F range. Not sure if that would factor in here.
This will be my second change overall. Any additional advice is certainly welcome.
