Alyssa Jean
Active member
- Joined
- Nov 2, 2003
- Messages
- 2,376
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Vessel Name
- Alyssa Jean
The brakes are locked up on my King Trailer. It has surge brakes. Yesterday I was barely able to move it. Visually checking I can see the pads tight against the brake plate. I am guessing that the brake fluid resovoir/piston lock-out mechanism is rusted somewhere so that the piston is stuck in the actuated position and holding the brakes in the "braked" position. Anyone know how to tear into this and possibly fix it?
The tongue hitch slides into the trailer about 3" and that is what must physically depress the brake resovoir piston. There is also a lock-out solenoid that is energized when you are in reverse. But it is all enclosed. This is happening both in going forward and reverse. I tried the wood block method of blocking the slide so I could go in reverse. Nothing.
