OK, here's a dumb one for you--on a Honda BF90, does fuel flow through the low-speed jets at all speeds, or only low speeds. In other words, when you are at full throttle, is the engine being fed by all jets or only the high speed jets?
I ask because I'm needing to clean out the low speed jets with Sea Foam, and wonder if I need to sit at 2000 rpm or so to actually be working it through the carbs.
tx,
bmc
tx,
bmc
